Re: Steel Dome Oven
Your smoke will always go from hot to cold. The larger the difference in temperature the better the draw. Somebody
posted a spreadsheet that calculates chimney draw on the forum that you can use to check this. So.. Once you insulate, your oven will run hotter, creating a larger difference between the oven chamber and the outside air. Additional chimney height can also help.
Bruce
posted a spreadsheet that calculates chimney draw on the forum that you can use to check this. So.. Once you insulate, your oven will run hotter, creating a larger difference between the oven chamber and the outside air. Additional chimney height can also help. Bruce
