Re: Steel Dome Oven
Wiley, Is the perlite for thermal mass or just insulation. I am building one like yours but it will be inside a structure so space around the oven is unlimited. Thinking of using 2 domes (putting slices in the outer dome to fit over tight) for thermal mass then using insulation of ceramic wool or other material. Do I need more thermal mass before the insulation?
Thanks,
Randall
Re: Steel Dome Oven
Trailer was previously modified by whomever built it. It was a mobile home trailer that had been shrunk down but is super beefy. Craigs list score. Shocks may be a bit stiff but seems to travel better now that I have weight on it. Did end up cutting some pieces off, adding a few.. Main thing was attempting to get weight distribution correct. Built oven frame and then moved it back and forth a bit before welding it to trailer.
I bought this because of its height and double axle. I added the square beams that oven pads rest on that were 8" and pad is about 8" which gave me correct working height. I also designed this so a fork lift could remove oven if needed. Now that I am more familiar with welding I think one could frame up any trailer to the correct height without to much trouble but helps to start out up a bit.
john
Re: Steel Dome Oven
that is a perfect little trailer, did you modify it any?
Re: Steel Dome Oven
Steel dome oven creators..
Just got my steel dome oven up and running and working great. Thought I would post my experiences in short for those who are headed this route. First and most importantly, my oven is working great and pizza, bread and other goodies are first rate.
What I did.
Oven is mounted on heavy duty trailer. Built a boxed frame out of 1 1/4 steel tubing with angle iron reinforced bottom. Wrapped this with metal lath, small stuff and filled the entire base with Vermiculite/portland cement mix. This is insulating pad. The outer dimensions of my frame is 58" which is the diameter of my buoy which became my oven cap. The internal dome is propane tank. 41" diameter. This rests on its own framing 1 1/4 inch tubing that is welded to the entire insulated box. The fire brick is set into the 41x41" frame on top of mortar/fireclay mix embedded on all sides with vermiculite insulated pad. The design of the inner dome I based on Kiko Denzers Earth Oven book which uses clay domes. Cut door at the 63%. Mounted steel dome and cut door and welded entrance door to this. From this point I welded rebar spikes around the dome, looked like a silver porcupine that I connected with wire. This was to give the fondu/ 1/4" minus basalt heat sink mix something to hold onto for the bumpy roads. Did the heat sink few inches thick and in 4 sections allow for expansion of metal. Foil under all of this to allow for slip. Having the rebar protruding from this made it easy to wrap all this with Kaowool and then more wire to hold it tight. At this point I capped the whole thing with my huge buoy. What I ended up with was a steel framed oven welded all the way down to the trailer. So far so good. Got the whole thing up to 50 mph other day. Time will tell how it holds up but only week link I can think of could by the firebrick inside but they are solid.
Some observations so far. Kaowoll is amazing. Outer dome is barely warm to touch with oven temp well above 600. Thermometer only goes to 600. Vermiculite/cement mix also is working well as bottom under oven is barely warm with firebrick blazing hot. The Heat sink principle seems so basic but I really didn't get it until I got this oven going and did my baking. To come out next day, 12hrs later and open door to find oven still at 150 degrees I started to see it all coming together. A well insulated heat sink. Seems simple but going through all the motions of building and following the principles makes much more sense to me now in practice. Have a steel door that I prop at an angle for bringing up to temp. When raking coals out I push the door in front of chimney pipe and against inner dome sealing in heat.
Now I'm making the oven look somewhat professional. And learning how to use it. Time/temps/wood used. Really amazing how such small about of wood can create so much heat. This project was built from salvaged materials, cutting metal with torches and hand saws and arc welding from a generator. Long road but well worth the pizza and bread so far. Now second phase will be to study longevity of trailer oven and all its parts.
Oven looks like giant buoy with a chimney. Plan is to do personal catering. Thinking of names, any suggestions...
john1 Photo
Re: Steel Dome Oven
Hello to all
A domed-shaped oven relies on induction technology to provide heat. In particular, the oven has a dome or igloo shape, preferably modeled as an Italian dome oven, for use in a commercial pizza facility. The dome is made of a heat conducting and holding material such as concrete or stone. In the bottom of the oven, a magnetically susceptible plate is interposed between two layers of concrete. Beneath the lower layer of concrete, an induction coil provides the energy necessary to inductively heat the plate sandwiched between the concrete layers. In alternative embodiments of the present invention, additional plates are interposed between layers of concrete throughout the dome. Additional induction coils are provided proximate each of those plates.
Thanks for sharing
Re: Steel Dome Oven
Hello Friends.......
I just found your topic and I am interested in building a Steel Dome oven. I read your directions and they sound pretty clear. We'll see how our creation turns out...
Re: Steel Dome Oven
Firebug, I have used 1/2 inch Hardiebacker to prototype a door for my WFO and found that as it gets near 500F it starts to give off a very unpleasant odor and it becomes quite fragile of the course of a dozen or so firings. In my case it lasted long enough to try out the shape I wanted which I then created in steel. I kept using it to see if the odor would eventually go away. It lessened but the door became so fragile it easily broke.
As you are thinking of having the sand against the cement board and it will easily get to those temps I would advise against using it. 16 guage steel is easy to work with, thick enough to be fairly easy to weld and yet light enough to be easily shaped, bent, sheared or cut with a saber saw. 16 guage by coincidence equals 1/16 inch or .0625 inches, for manufacturing .06 is the usual nominal thickness.
Hope this helps,
Wiley
Re: Steel Dome Oven
Wiley
I was thinking something similar with the metal,What if I built my enclosure walls out of 2x6 metal studs put the kaowool in between the studs and put dura rock (or equivalent) on both sides of the 2x6 walls then fill it up with sand that way its protected from collapsing the insulation. the oven should weight about 5-6 k lb max and my traileris rated for 10k lb so I'm good there, the trailer also has brakes but who knows how they work, thanks for the reminder I better look into that.Again thanks for all your support and knowledge.
Re: Steel Dome Oven
Firebug, I think I would want a steel sheet (something on the order of 16 guage) on the inside of that steel framework and attached to it. That way over time the kaowool would not be compressed to a thinner layer by the sand as it is shaken and settles during travel. It would also keep a more consistant thickness of the heatsink over the outside of the barrel. I don't know how familiar with kaowool you are but it is in consistancy much like wool such as one used to be able to get for dressings for wounds. Kaowool has a curious feature in that it squeaks when one squeezes it. The sound is faint but definitely audible if you listen close for it. If you simply poured the sand between it and the inner barrel I think it would definitely compress.
Also I would want to have an access hole on the top so that you could top up the sand as it settles. For sand I would see if I could find spent greensand from a local foundry. It's usually olivine, a high temp mineral that would be perfect for a heatsink. I would think you could get it for free or for very little cost.
I think it would work well. I suspect it will be a heavy WFO and need a significant trailer to hold it and truck to pull and more importantly, stop it.
Bests,
Wiley
Re: Steel Dome Oven
Wiley,
I think the route I will be going will be building a barrel dome out of half inch steel, place it on my trailer on a prebuilt base with 5'' of perilite portland cement base with fire bricks on top,deck size will be about 4'x6'.then I will build a steel frame around oven leaving about 8'' from inside of wall to outer shell of oven,on the inside of wall I will wrap several layers of kaowool it will be 3 or 4 inches thick,there should be about a 4'' hole from dome shell to kaowool insulation,then for the heat sink I will fill up the hole with dry sand.I don't think the insulation will compress much. and i will do something similar for for the roof.so to recap steel dome 4 to 5 inches of sand for heat sink then 3 to 4 inches of insulation.do you think this could work? thanks so much.
Re: Steel Dome Oven
Firebug, The Fondu is simply the binder, in my WFO the principle heatsink is the crushed basalt. In lieu of basalt any dense rock would probably work. Fondu is a trade name for calcium aluminate cement.
As to the properties of the Fondu itself, it is darker grey in color than usual Portland type cement and to my eye I detect a slight greenish tint to the color. It sets quite quickly and so small batches were the rule for my mixing.
Using crushed (1/4 minus) basalt just as it came from the pit I mixed by volume 5 parts crushed basalt to one part Fondu. I used a 1 quart plastic yogurt container for measuring and if memory serves the biggest batch I mixed was two containers of Fondu and 10 of basalt for a total of 12 quarts. I mixed by hand in a wheel barrow. I also used separate containers for the cement and the basalt and for the water as I didn't want cross contamination.
The material is sensitive to the amount of water added and quickly goes from a too stiff to a too wet consistancy. I started with one part of water to my 1 to 5 mix and then added slowly water by hose, adding and mixing and adding and mixing to get the right consistancy. Once at the right consistancy it is easy to work but like I said it sets quite quickly, with an ambiant temp of around 70 to 75 degrees it becomes stiff/"goes off" in about 20 minutes. Re "tempering" by adding more water and quick mixing will give you a few more minutes once it starts to harden but is something the directions on the bag do not reccommend.
Fondu is not cheap, in fact I would say it is fairly expensive so in the interest of economy, if you are building a stationary WFO I sort of feel that the Fondu may be overkill. So if money is tight I think one might possibly get away with using another mix, perhaps using lime and a little Portland cement as the binder. There is a company in AU that builds WFOs with two domes and they use dry sand as their heatsink so one isn't asking too much of the binder, just to hold the crushed refractory together. When completed the sections are supported by the steel dome and are not subject to abuse by oven tools. One would be breaking new ground going with a cement other than what I used but all life is more or less an experiment. Using a lime and Portland binder one should also have a longer working time although the downside is the Fondu allowed one to work without waiting for the previously poured/trowled sections to harden. By the time one cleaned the wheel barrow and the tools and started measuring out another mix the section just completed was quite hard and could easily support the new material. One might have to work with a stiffer mix and/or wait a day or so between sections if one used a Portland lime mix.
As for availability, I purchased my Fondu from Glacier Northwest and they have recently been purchased by another company, CalPortland. I see that you are in the Portland area, here's a link to their outlet in the Portland area:
CalPortland Company
I noticed in their list of products a type of cement which I am unfamiliar with called type "G". They say it is for higher temperatures than usual Portland cement (not furnace, however). I do not know its properties but depending upon its price it might be worth trying in some combination with lime.
Sorry to run on so, but hope this helps,
Wiley
Re: Steel Dome Oven
Thanks wiley I will do that,can you tell me a little about the ciment fondu,does it become a heat sink,does it hold on to the heat well?how much does the stuff cost?and where can I find some....thank you very much for you help.
Re: Steel Dome Oven
Firebug,
When you say "covering the metal vault" I'm thinking you are meaning the welded up firebox? And do you mean after it is placed upon the base (firebrick over perlite/cement insulation)? If that is what we're discussing, and since this is an experimental WFO, I think I would be prone to make things simple and in such a manner that one could easily get back to the steel vault should you find that you need more thermal mass. I like your idea to build the enclosure such that you can fill it with loose perlite. It's not as expensive as kaowool or other ceramic blanket and if you need to do work on the vault all you would need is a clean shop vac and some plastic trash bags and you can get the stuff out and still have it reuseable. Space isn't a concern so 8 or more inches of dry loose perlite might be all you would need.
Your mention of Portland brought this to mind.....and this is a wild idea in that it was something that came up last winter and I have no idea what the situation is regarding it at present. But there was an offering for free supersacks filled with perlite at the airport. If I remember the story right somebody had the stuff (100,000 lbs) stored there and couldn't pay storage they wanted/needed it gone and fast. Had the weather been better I and a friend were going to participate in the deal. I think I would give a call to the airport and ask a few questions as to who got the stuff and where did it go. There is the off chance that somebody scooped up the deal and would like to be rid of it themselves. Or perhaps sell what you need less expensively than retail, because I think you are going to need alot. Check archives for 11/19/08 a posting by Jed. The Craigslist posting is dead but somebody will know something at the airport, (and I'm fairly certain it was at the airport. But then again my memory is good, just short).
You might start your own thread as this will be a WFO alot of people I think will be interested in following.
Bests,
Wiley
