Clay oven
  • Paulhilton74
    • Apr 2020
    • 2
    Clay oven
    Hi all.
    seem to have got the bug now to build my own pizza oven from clay. So thank you!
    a few questions if any of you could help me with.
    - what clay can I use, is normal terracotta clay mixed with sand ok?
    - for the 2nd layer, has anyone used the fibre blacker over the clay with chicken wire and then applied a layer of clay over that. Or is it best to just stick to clay.
    - lastly. How many 12.5kg would you expect to use on a small oven.
    thanks in advance
    paul
    • 5264
    We do not see many cobb oven so response will be limited. If you are going through the effort, why not consider a homebrew refractory cast oven over a sand mold. There are several examples in this section of the forum and with a little research on your end, most all the answers are located here along with some well documented builds.
    • Paulhilton74
      • Apr 2020
      • 2
      Thanks for the reply
      • burnt_edges
        • Feb 2020
        • 4
        Hey there, i have found a bit more about cob ovens over at the permies.com site (i have been building a clay oven myself)
