30" cast dome design
  • #61
    Originally posted by sergetania View Post
    Mullster Thanks!
    Yes, that's exactly what I was hoping for. A vcrete layer and then paint over with a waterproof coat. Do I need anything on top of the vcrete before waterproofing? Won't it work? I have no idea hence I have asked.
    Vcrete is going to be pretty porous. I recommend stucco over your vcrete, then finish and seal your stucco. Note, no cement product is waterproof, however stucco is more water resistant than vcrete.
    - George
    https://community.fornobravo.com/for...mente-ca-build
    • #62
      George,
      Is being porous the only reason why I need the stucco layers? In order to seal the vcrete? This product recommended by david s in one of his posts is 100% waterproof so it should do the job and no stucco is needed
      Is David around? Trying to figure this out. Thanks!
      • #63
        George,
        If it's recommended applied over vcrete then by all means go with it and save yourself some work.
        - George
        • #64
          That's what I have been trying to find out. It should stick and waterproof. What else do I need? It would be nice if I could skip the stucco. Especially the brown coat! It just doesn't sound good
          • #65
            Done with the facade. Glued the tiles to the bottom of the form with silicone. I will need to figure out how to get the silicone of the tiles. I should have used something else. Do I love the look? I think it is decent and hopefully will get better when dry, clean of silicone and framed with the outer layer.
            Click image for larger version  Name:	20200905_131927_HDR.jpg Views:	16 Size:	335.7 KB ID:	429869
            Click image for larger version  Name:	20200905_163727.jpg Views:	8 Size:	312.9 KB ID:	429870
            Click image for larger version  Name:	20200908_182124.jpg Views:	9 Size:	396.6 KB ID:	429871
            • #66
              How does this look? I think the wire holds it down well enough.
              Shall I start the curing fires or wait till the outer layer is in place? Thanks!Click image for larger version
              • #67
                Shall I start the curing fires or wait till the outer layer is in place? Thanks!Click image for larger version  Name:	20200912_170032_HDR.jpg Views:	0 Size:	795.7 KB ID:	430028
                If you mean putting the flue in place first and then firing I think it could be ok - personally I also got the vermicrete layer on top of the blanket too before starting.
                My cast oven build thread
                https://community.fornobravo.com/for...-castable-dome
                • #68
                  The outer arch looks nice. I’d attack the silicon with a stiff scrubbing brush then grout the tiles with a black grout.
                  most builders use a 10:1 vermicrete or perlcrete over the blanket to restore perfect hemisphere and to provide a firmer substrate to render onto for the final outer shell. I like to drive out excess water after vermicrete layer but before outer tendered shell.
                  • #69
                    Yeah, I guess I would need a flue
                    • #70
                      david s Thanks! Missed you - hope everything ok!?
                      David, not sure you have seen a discussion above. I am planning to waterproof with elastomeric flashing sealant
                      ​​​​​​​ https://www.amazon.com/dp/B004SIB2JI..._iaExFbEW59BBB
                      over the vcrete layer (with breather) skipping the other render. Ok or bad idea? I may need to smooth out the area around facade but otherwise, why do I need to do stucco all over vcrete? Thanks!
                      • #71
                        Sorry, been out of action, in hospital for the last 4 weeks. A nasty staf bug got into my blood, attacked my aorta valve flicked off some bits to my brain causing minor eyesight problems and major back pain. Open heart surgery to replace valve and long term antibiotics to kill bug, hopefully going home next week. To answer your question, some folk have rendered against blanket successfully, but it is quite springy and not a good substrate to work against, resulting in inconsistent outer layer thickness. A layer of vermicrete over the blanket can restore a perfect hemisphere, evening out the lumpy blanket and giving you a nice firm substrate to work against.
                        • #72
                          David, very sorry to hear about the health issues! Sounds really nasty! Glad to have you back and wish you the fastest recovery!
                          Sorry, I was not clear. Definitely doing a vcrete layer but want to skip a stucco layer(outer render) and just paint the vcrete with flashing sealant. Good or bad idea?
                          • #73
                            Maybe you can skip the stucco, I just like a nice strong outer shell. It is after all just protection for the inner oven.
                            • #74
                              In that case a mix of 3:2:1 vermiculite, sand, cement should be sufficient. I’d be choosing fine grade vermiculite
                              • #75
                                David,
                                Sorry,are you saying I should be using 3:2:1 mix instead of 10:1 vcrete for the 2" layer on top of the blanket? I thought I could do 10:1 2 inches vcrete painted with the flashing sealant. What is the 3:2:1 mix for? Sorry about being confused!
