I'm waiting for materials to be delivered to start my base with the intention of building a 800mm homebrew cast oven.
Like everybody I have questions.
I have to build it on a budget, so it may take a while to source the materials at the right price.
I have, very kindly, by a member on here, been gifted 120 kgs of pumice stones that I intend to use as a large part of the insulation along with rockwall.
My intention is to give the cast dome a coating, maybe 40mm of pumice, then 75mm of rockwall, then more pumice with a rendered topcoat.
david s in a previous posting you recommended that the pumice particles should be no larger than 6mm, can I ask, is that for superior insulation or ease of use?
The stuff I have is stones, 20/30mm with rounded edges, if I have to crush it to less than 6mm I'm going to end up with mostly sand. Do you think it would be ok to crush it a just a bit, A, to give it sharper edges so it "interlocks" better and B, to make it a bit easier to work with.
You also said that you had used rockwall as an insulation once but it was difficult to use as it crushes too easy.
My plan is to use half inch weldmesh over the rockwall instead of chicken wire, stiffened with some strategically placed stainless 5mm helibar. Not sure if it's called weldmesh in Oz? Square galvanised welded mesh, I think 19g?, much stiffer than chicken wire, I use it on my coops, a fox will bite through chicken wire.
I'm going to use thermolite blocks for base insulation, I could make room for 30mm or so of pumice as we if you think it would help, under or over the thermolites?
What do you think?
What do you think?
