Firstly, like many say, the information on this site is incredible, so thank you to everyone who shares their superb knowledge.
I am at a stage where I have moved away from a traditional clay cob idea. Instead I plan on making a home-brew cast.
Apologies in advance for a lot of questions, but I have spent a couple of days on and off reading the posts, yet there are still a few knowledge gaps, so any help will be massively appreciated...
I have already made the base and the concrete plinth (100mm deep).
I have bought some Quinn Lite Super blocks - 0.12W/mK Thermal rating. These are (unless someone tells me otherwise) a direct comparison to the Thermalite blocks, just a different brand. I intend to use these as the insulation.
Next step is to lay 64mm fire bricks, using a thin layer of kiln sand between the fire bricks and the thermalite blocks, to achieve a perfectly level cooking surface.
I hope to use the kiln sand to fill any small gaps between the fire bricks and the house bricks that make up the external wall / barrier which surrounds the fire bricks and below them, the thermalite blocks.
Q: will I be ok taking the fire bricks up to the edge of the house bricks (i.e. filling the whole area I have made available - as this would be easier for me than cutting the bricks to the dome shape), therefore meaning the fire bricks will protrude out from under the edges of the dome, or must they stop at the edge of the dome (I have asked this because I gather that there may be possible heat loss if I do it this way).
Q: The overall width and depth of the available surface the dome will sit on is 108 x 108cm. As I had intended to make a clay cob, with walls potentially 20cm thick around the dome, I estimated that I would have a cooking area of 68cm. AS I now plan to make a home-brew, I understand that the overall wall thickness will be less, therefore, more cooking area. Can anyone advise me roughly what the cooking surface will be?
I plan on making two brick walls for the gallery entrance, with a cast section on the top (I have seen a photo by DavidS somewhere that gave me this idea).
Q: DavidS advised me to drill some holes through the concrete plinth to allow for drainage. I have drilled five 10mm holes, within a 20cm diameter area. Will this be suffice? (Pic attached)
Q: What will I need exactly and where will I get it from in the UK please?
I have stolen the following list (slightly amended) from Robarb (thank’s for that).
Sand
Clay
Cement
Lime
Fibres
Needles
Twin-walled flue
Firebricks
Vermiculite
Insulating blanket
If anyone can help me to understand quantities and suppliers, I would be very grateful. Also, if there are any material specifics I need to be aware of.
I think my overall sizing will be very similar to that of Robarb’s oven, judging by hos external sixes, indicated in this thread: https://community.fornobravo.com/for...rew-cast/page2
Please accept my apologies if I am asking people to repeat what they have already posted (pretty sure I am), but I have had a good look around the forum, yet it still hasn’t ‘clicked’ with me enough to just get stuck in myself without a helping hand or two.
Tony.
Sand
Clay
Cement
Lime
Fibres
Needles
Twin-walled flue
Firebricks
Vermiculite
Insulating blanket
Tony.
