Hi All, I'm new here today and could do with some advice. I've part built my oven as follows...
Made a vermiculite/cement slab for the base, 4 part vermiculite 1 part cement left to set for 24 hours,
On top of the slab I laid 1 inch fire bricks on 10mm of sand for the oven floor,
Built a former from sand then covered in wet news paper. Then applied a 2 inch layer of vermiculite and cement same ratio as the slab to make the dome
left over night then set a small fire.
I noted some smoke escaping from the dome so applied another layer of vermiculite and cement. And that's where I'm up to, Can I ask how long should I leave the dome at this stage to set before starting to cure?
After that I plan to cover in ceramic fibre insulation then apply a final layer of regular cement finish.
Any suggestions or changes I should make would be very much appreciated
Cheers,
Bill
Cheers,
Bill
), you would benefit from using it just to see if you would use an upgrade or just turn it into yard art. My main concern with using vermicrete domes is the higher possibility of "topping additions" from fallout. Definitely going to get more use and options with homebrew or refractory mix come and it will be less work now since you've gotten some experience with casting techniques. One good thing is you'll be able to tear the vermicrete apart quite easily. Lots of options, but as Rob noted, having something that will be used a lot and stand the test of time is a big consideration.
