It has been about 3 weeks since I placed the Vermiculite/Perlite layer over my homebrew cast dome. This includes a week of firing.
I am ready to add my stucco/render layer on.
My plan is to use a 1-1-4 (portland cement, lime, sand) mix, with polypropylene fibers and acrylic fortifier. I plan to make the layer 20mm (3/4 inch.) thick.
I will sponge some water on the dry vermiculite/perlite layer first.
I do not plan on using chicken wire.
I will cover the stucco/render layer with cling wrap for at least a week to damp cure it.
Any suggestion on this plan? I could use the chicken wire if it is worth the work.
I am a little bit worried about the water loss into the vermiculite/perlite layer, but not sure much could be done about it, I don't think it would be wise to really soak that insulation layer after purging all that water out of it.
Any thoughts are appreciated!
