Apologies if this has been posted before but I'm having trouble finding the answers to a few of my questions
I'm relatively new to the forum. Got a strong desire to build a pizza oven in the past month but there's not enough time before winter to fully plan/measure/build anything. So i get to spend the winter researching and collecting materials so i've got everything as ready as possible.
From base research i've determined it's going to be a 36" pompeii style oven. Ideal usage would be about once a month for pizza and then some bread (either with the thermal inertia or assisting the hold in temperature) I will build an enclosure filled with insulation so that the dome is completely protected from rain and snow (i live in middle Sweden). What i'm having trouble with now is choosing between a homebrew castable and a firebrick dome. Price is a concern which is why i'm seriously looking at castable. Plus trying to find equivalent materials in Sweden is just a nightmare. I know the language rather well but this is advanced language stuff we're talking about here, not to mention general availability (i can't even find standard CMU here).
Some important questions I haven't quite been able to figure out yet:
What's a rough estimate of service life of a firebrick oven?
What's a rough estimate of service life of a homebrew castable?
I know from reading that a pro of the firebrick is that they are fully fire cured so I wouldn't have to worry about high temperatures in the oven at all and that with a castable I shouldn't go above 500C. My main question regarding this is, is this a realistic concern? Is going over 500C something that i'd have to actively try to do or could it happen accidentally.
I also just want some help with a general pro/con list for each of the oven types. I have never done WFO nor have I any other experience with WFO. Here's what i have so far
Castable
Pros: Cheaper, faster construction, not as advanced construction technique, thinner walls therefore smaller footprint
Cons: lifespan (rebuild after X years), parts availability (SS needles, etc)
Firebrick
Pros: lifespan (assumed to be quite long), measured and tested performance from countless builds
Cons: more expensive, steeper learning curve, more tools required (wet saw), longer construction time
Thanks for any feedback and sorry again if this is a 'repost'
Castable
Firebrick
