Planning a perlite pizza oven build, AR glass, Homebrew, Cob, experience wanted
  • neom
    • Jun 2025
    • 1
    Hello everyone!
    After rigorous reading up on home built pizza ovens I find myself here. My plan is to build a Pizza oven over the course of the summer, the whole premise is to have a fun little project that wont be too expensive but will last for years, not necessarily a lifetime, 10 years would be fantastic. I really need your help deciding on the right design for me and how to execute it!
    The only part that is decided is the 80 cm biscotto tiles for the floor. I will build on top of a sand form by Neapolitan design with a low roof (Ø85cm,29cm high and 18 cm opening)
    The options I see:
    1. A solid cement : perlite oven. 6cm 1:5 mix, chicken wire, 5cm 1:6 mix, chicken wire, 4-8cm 1:6 mix (finishing shape layer), waterproof mono-coat, render, mosaic. From what I have seen thick reinforced perlite ovens are the most successful ones. I understand that cement is not optimal under high heat but still I see successful ovens made this way, it seems beneficial that the ovens seem to slowly crumble rather than just crack and some seem to be quite stable! Benefits; homogenous material reduces stress from heat, perlite is stable under heat, high insulation limits the parts affected by high heat, easy/inexpensive. What do those of you who use this kind of oven say, does it last, have you done alterations to your mix, are you able to repair them? Is there alterations I could do to this recipe? I have been pondering adding clay or lime and adding some fibers like straw to add strength to the insulation layer. Concerns; I have seen some real horror examples made this way (often involving an inflatable pilates ball), however some of these where clearly missing any reinforcement hence its hard to judge which one is a well built example actually failing.
    2. The forum favorite homebrew fire layer perlite oven. 5cm 3:1:1:1 homebrew with AR glass fibers, 4cm 1:6 mix, chicken wire, 4cm 1:6 mix, chicken wire, 4-8cm 1:6 (finishing shape layer), waterproof mono-coat, render, mosaic. This is one I see a lot of people going for in this forum. Benefits; Fire resistant layer, hard durable inner layer, added thermal mass, not too expensive (if it works). Easy to repair. Is there anyone that have a design of a homebrew that have lasted you for some years? What other alterations can you do to the homebrew, I have been thinking about adding grog (crushed ceramics) for increased thermal stability. Concerns; I have seen examples here where the homebrew cracks quite severely. The homebrew might be prone to chipping of the structural perlite layer? It is difficult to reinforce the homebrew I have not seen finished examples of AR glass, anyone know of any? AR glass is hard to come by and expensive (probably worth it). Two casted layers that expands differently under thermal stress. I have a lot of hope on this option but not without some fear of that the added complexity might make it both more laborious and more prone to failing. You who have made a homebrew oven what did you learn and what is key to a good design? In some blacksmith forums I have read about mixing silica sand, cement, clay, perlite, and hydrated lime, anyone who has tried? I have also read about Sodium Silicate is this a longevity enhancer?
    3. The cob(1:2 clay:sand mix) perlite oven! 5cm cob, 5cm clay perlite straw 1:4:1, chicken wire, 8cm clay perlite straw 1:4:1, render, mosaic, roof! . Benefits; easy to work non toxic materials, repairable, reusable( if the oven becomes too cracked its just to crush it up, add water, mix and build up again! I don't see that many cob/clay ovens using perlite, is there any here who have some experience? Concerns; It will crack (from experience) but probably not fatal, not as insulated, unsure about the compatibility with perlite and mixing ratios, longevity might be limited (at least traditional cob ovens)
    I am grateful for any insights you might have! I am open for other suggestions too! I see the low thermal mass of perlite as a benefit in my situation, with faster upstart times and fuel efficiency in comparison to a chunky brick oven. Since the biscotto tiles, stainless chimney and base is reusable its not the end of the world if the dome fails. But I really hope not. I will cover it with a sown tarp when I am not using it to keep the oven out of the elements.
    If you made it all the way thank you!
    Best regards
    Rasmus
  • rsandler
    • Apr 2012
    • 363
    Do Option 2, or something like it (chicken wire embeded in your insulation layer sounds sketchy, but I'll defer to others on that). The YouTube phenomenon of the "perlite oven" is pernicious. For a pizza oven, you want dense thermal mass to soak up heat from your fire and radiated it back onto your food. Perlite has very little mass--it's virtue is as a lightweight insulator. It won't heat up faster than a dense mass--in fact it will resist heating up at all. That's why you see cast ovens on here built out of 3:1:1:1 homebrew or commercial castable mixes, and not out of perlite. That's also why you don't see perlite mixed into cob ovens. You do want insulation--on the outside of your thermal mass, so that the heat you're putting in from the fire stays in the mass rather than being radiated out into the air (this will reduce heat-up times. Perlite, whether loose (in the case of a doghouse-style enclosure) or as concrete is a perfectly valid solution there.
    A cast oven does have the virtue of being stable with thinner walls (5cm is acceptable, compared to around 11 for bricks), so you're likely to have faster heat-up than with a brick dome, even with a proper thermal mass.
    Cracks in wood-fired ovens are inevitable. As they say, there are two types of WFO owners: those whose ovens have cracks, and those who lie about their ovens not having cracks. Mostly they don't pose a structural risk.
    As a last point, perlite concrete has very little structural strength; it's somewhat spongy even when cured. This means 1) it won't work well as a self-supporting dome and 2) expansion from a dense dome cracking the perlite layer isn't something most people worry about (you do, however, need to worry about steam, so letting both layers dry before exposing it to extreme heat or covering it with render is very important).
      • 5260
      Agree with Rsandler, there are several well documented cast ovens in the Newbie Section under treasure archives. For the most part, perlite/vermiculite/concrete mix is NOT used as the main oven material but for insulation purposes.
      • Michaelc
        • Mar 2025
        • 3
        Hi Rasmus,
        Re cob.
        Cob ovens perform very well, are fun and cheap to make and in my experience last for years but they need to breath or they will collapse. Under a simple roof is fine but if you render and mosaic it it it will get soggy inside and fail. Water glass misted on will stabilise the cob inside and out.
        I would also consider going a little bit thicker to add stability also.
