Ready to build... ...but with questions:
  • GregYo
    • Sep 2025
    • 18
    This is my first oven build. I've been reading over FornoBravo plans, and talking with others on other forums. My plan is to use homebrew 3:1:1:1 (or AR fiber variation) to cast over a plastic mold, and use FB methods to build my outdoor oven. The main body of the oven will be casting only, however bricks will be used on arch. I just finished pouring the cement counter tops, and am gathering materials for the oven build.
    Oven info:
    Internal diameter will be 29"
    Ceiling height: 20"
    Door height: 13" (Should this be lower, say 11" ?)
    Door width: 16"
    The Premio 2G 100G oven has a 65% door to oven height ratio, and this oven would be the same.
    Regarding the casting, what do you think about setting up the mold so that it has 3 separate dividers?
    The advantages would be: Easy to move; oven joints would easily allow oven to expand and contract.
    The mold is a Dogloo, but will be cut down by 6 inches to keep the height closer to spherical.
    You have any suggestions on types of oven coatings that help keep it dry, besides a patio cover over it?
    Your mould is considerably higher than a hemisphere. Not sure how thick it is but it may be quite difficult to cut and remove. You will also need to create an oven mouth, maybe use polystyrene or sand. After casting the dome and mould removal you will need to construct another mould in front of the dome so you can create the cast in situ flue gallery incorporating the rebate for the door. If you are unsure about this there are plenty of well documented cast oven builds under "Other Oven Types" On creating a multi sectioned dome, it is quite difficult to do this using a cast in situ method, particularly if you want to create stepped joints. A single one piece cast is far simpler.
    • GregYo
      • Sep 2025
      • 18
      Yes, the plastic mold points upward, but the sides haven't been cut down by 6 inches. I plan on making the cast about 2 inches thick.
      This may be way out in left field, but what if I were to use high strength tape to create a seam, dividing the dome into 3 parts - much like the Casa2g Series dome. The tape would stick up 2-inches above the dome from top to bottom, the cast mud mix would push against the tape on both sides. Once dried, each 1/3 piece would come off the mold and be placed onto the oven floor area with refractory cement on the seams.
      If it is reasonably possible, then it wouldn't need to be done in situ. The seams would not be stepped, but the hardest part would be aligning the 3 dome pieces. I plan on casting the flue and the rebate for the door in situ, once the dome is in place.
      I haven't seen this done, probably because it may be easier to build in situ with sand cast...
        Try it and document how it goes.
        • GregYo
          • Sep 2025
          • 18
          David, if I make a 3-peice cast using the homebrew recipe, what is the best refractory cement to use on the seams?
          Also, is there a way to move this post into "Other Oven Types" section?
            • 5260
            I moved your thread as requested
            • GregYo
              • Sep 2025
              • 18
              Amazing how slow things go, when you only have weekends to work. The plastic mold was cut down to the dimensions mentioned above. I sanded down the concrete counter tops, and they'll be ready for sealer shortly. I'm trying to find the instructions on drilling breathing holes along side the insulated dome walls through the concrete base. Where can I find this info?
              I need to find the center of the oven on the base, then drill the holes, and finally receive all the ingredients for the homebrew.
                Regarding your previous question about refractory cement, you can just use the homebrew mix as that's what you are intending for the castings.
                For the holes to remove moisture from the dome insulation, they should be placed in the middle of the insulation layer. I use 10mm holes. Use about 4 equally spaced around the dome. Glue some small pieces of insect mesh over them to prevent insect entry. If water or moisture gets in to your under floor insulation a couple of holes near the centre of the floor is also advisable, as under floor moisture is the hardest to eliminate.
                • GregYo
                  • Sep 2025
                  • 18
                  Ok, great. Thank you.
                  • GregYo
                    • Sep 2025
                    • 18
                    Well, the 3-part casting of the homebrew 3:1:1:0.5 igloo dome worked well. The added 0.75" AR fibers really worked well to hold everything together. A day before I did the casting, I used an orbital sander to remove any of the Dogloo injection molding seams/lines. After drying, separating each 3rd piece was not that hard. Because of the duct tape separators on the dome, each 3rd piece casting fit together fairly tightly. The top of the dome has the thinnest casting, but it is still 2 inches thick there and its closer to 3 inches at the sides of the dome, so I think I'm good to go on to drilling drain holes, and setting up the floor of the oven.
                    • GregYo
                      • Sep 2025
                      • 18
                      Thank you David for all your help in my WFO project. I completed the 10mm holes and put a little steel wool into them to allow for drainage and breathability. It's not perfect, but it holds its heat fairly well, from what I can see. I'm working on slowly ramping up fires daily to remove any moisture from the dome. Next I'll plot out the heat characteristics from 800F to see the heat loss over time.
                      • frank1985
                        • Oct 2025
                        • 24
                        Hi Greg, any updates on this? Are those standard bricks you’re using for the archway?
                        • GregYo
                          • Sep 2025
                          • 18
ID:	470556 My WFO backyard project is 90% complete. I need to finish the color stucco on the cabinet area, and some minor trim areas. The bricks on the arch are color matched to the brickwork on the concrete floor. I could have been way more decorative with the style of this project, but being my first I kept it simple. I found a brick manufacturer/dealer nearby and was able to get seconds that look new. That is what I used for the arch - they are decorative bricks. So far, they have stood up to the heat. Its taken a couple of tries to find the right temperature for pizzas. I've found that 600F is too hot, so I'm now trying with 500F. Its a small oven, so it heats up in about 40 minutes. I've not seen any cracking on the outside stucco, and maybe a few minor cracks inside the dome. I've been using it for making pizza and many other foods. I placed a temporary door over the opening so no lizards or other animals find their way in. I have found this chef who has some nice dough and other main dish recipes. https://youtu.be/qyfB3wNGvCc?si=Ykv8RiQFQON8GSzL
