Cobb oven weight?
  • stellawood
    • Jun 2008
    • 10
    Cobb oven weight?
    Does anyone know approximately how much a Cobb oven will weigh?
    This would be a 27" diameter dome ( approx.10" total wall ), with a firebrick floor, plus the entry arch and clay chimney.
    I ask because I'm hoping to get away will putting it on a concrete column base with a floating hearth slab instead of the block stand, or a solid fill base.
    Thanks much
  • gjbingham
    • Sep 2007
    • 2021
    Re: Cobb oven weight?
    No idea really. I think it depends on how much straw you mix with the mud. I'm guessing that the whole shootin' match (oven/chimney/door) wouldn't weigh more than about 400 - 500 lbs.
    GJBingham
    • enz
      • Dec 2006
      • 41
      A 27" ID dome with a 4" floor will weight about 3200 lb. This is a quick and dirty calc without a doorway or arch, so it will probably be a bit less. It's in the ballpark though. Call it 3000 lb.
      Enz
