I am thinking about building a tandoori oven, which will essentially be a clay pot that is inside of a 55 gallon steel drum. I am taking much of my inspiration from this other site Oil Drum Tandoor . I live in Denver and there is a ceramics supplier here that I will consult for the type of clay for the pot.
My questions include the following:
1. What should I use for insulation around the exterior of the pot? Do I need to use FB Blanket insulation or can I use something like crushed glass, tile or something else?
2. Do I need to install firebrick on the bottom of the pot, both inside and out, in order to use charcoal due to the heat?
3. Should I just line the steel drum with fire brick and put a tapered clay cap on the top? I have about 200 fire bricks available so that I could just line them up vertically and mortar them in place, with a thermal blanket between the bricks and the steel wall. I calculate that I would need about 120 bricks to do 4 courses, plus a bottom layer.
4. Would I be able to cook a pizza on the bottom of the oven or would it not cook the pizza efficiently due to the conical design?
Any other comments would be helpful.
