I think I have decided to build a low dome clay oven, primarily for pizzas. Like most people I have spent ages reading through as much as I can find, and this is where I have got to:
I am looking for 36'' internal oven diameter, as I want it to heat up quickly, I am pushed for space, and a pizza at a time is fine with me.
I am going to build it directly on the ground, on a bank of earth. I will flatten the earth and make a solid bed for the oven.
I am not sure if I use clay from the soil, or buy some...
I will use lime mortar for the external render, for waterproofing. NHL 5.
The oven floor, I have some large terracotta tiles I hope to use.
So, if anyone would like to advise on anything I have listed that would be great. My main questions are:
1. I am placing the hearth on soil. What insulation would you recommend, and what sort of a base to keep it all from moving?
2. Can clay heat up enpugh to give 400C degrees?
3. Will clay be strong enough for a low dome?
4. Am I mad?
Many thanks for any responses...
John
4. Am I mad?
John
