-i made a base for the oven:
cinder block, 3/4" steel plate top, then 3 inches concrete over that.
i have a layer of fire bricks for the oven floor.
i plan on making the first level of the oven with firebricks on ends(going verticle) with a homemade dome on top of that.
my question is with the dome. would anyone see any problems with making a dome out of refrax mix using a metal oven top as a form? I have a dome shaped oven top, similar to a basic weber type chargoal grill but not as high. I plan on coving that with newspaper, which can be removed, or burned off later. then just cover the dome with refrax mix and rebarb. I also plan on leaving a hole for the chimney on one side. i thought after i get a thin layer, i would place thin nails in the refrax to gage the thickness all around the dome.
does this sound feasible? has anyone else used this technique? finally how thick should it be? I haven't decided how I will finish the top yet. I'll either build a block base around and cover inside with vermiculite, or just cement over the entire thing. I'll worry about that later though. I'm just concerned with the dome top now.
Thanks, Aaron
Thanks, Aaron
