Re: Small Portable Tandoori Oven Build
Now it was time to work out how to fix the lid back on! We were hoping to implement something a little more elaborate, as it would have been nice to have fixing tabs on the inside as it would be more visually pleasing...but it all got too difficult so we fixed 3 tabs on the outside.
The idea was to weld 3 x 10mm stainless nuts to the inside of the keg. The lid would then be fixed to the keg with 3 bolts through the tabs. Sounds pretty strait forward.
First task was to make the tabs using a sturdy drill press. Again, drilling stainless is not as easy as you would think.
The lid was aligned with the keg and taped up with strong gaffer tape. 3 tabs were welded into place, equally spaced around the keg. This was all fairly strait forward.
With the tabs in place, we found another excuse to use the plasma cutter. That is, to blow the hole for the bolts. It "kind of" worked as you can see from the final picture, but the holes need significant work with a step drill to finish off (complicated by a lot of flat battery drills). Still, it was probably quicker than trying to drill 3 x 12mm holes in 3mm stainless.
Luke
Luke
