Re: Cast Oven on Trailer Questions
The main disadvantage of the small oven is the lack of interior floor area and the larger (by proportion) chunk of oven wall lost to the door opening. I was really worried about getting it off the trailer because of the weight. But with my system I think my set up would easily handle another 50% weight so I could have made it a bit bigger.If you have a tractor with hydraulics for instance, you could move it on and off that way. The smaller the combustion chamber is the more difficult it is to make it fire well. I found this out when making pottery kilns, although I have no complaints about how my oven fires. The dome being closer to your pizza could actually be an advantage, because it would get more radiated heat from the top of the dome.
