building outdoor kitchen with brick pizza oven
not sure if i should go with the 42 or 48 inside
1. have a 11 inch counter if front of oven opening
2. 48" would give me 11" from front of arch to inside of oven
3. 42" in oven i get 14" arch
4. so if i got this right that would be 22" or 25" from front of counter to opening of oven
5. concerns a) do i have enough room for vent trans. b) will it take a lot longer to heat up an 48 ver 42 inch oven
went to expo was great most there said bigger is better more room for fire and piazza's
just not sure of vent and trans
numbers where from bottom of dome
so if i set the vent back over dome can get more room just have make trans different
8" vent either way
8" vent either way
I just love saying that- thx for making that your forum name)
) and I can just barely maneuver things in the back of my oven. You will get used to whatever depth you end up with and the length of your reach, but I'm just forewarning you on the issue.
