Venting from indoors???
  • andrewpizza
    • Apr 2010
    • 17
    Hi everyone,
    I am opening a small italian pizza take away shop and have decided to use the pompeii oven plans, scaled up to a 5 foot internal diameter. The only problem I have is I cant go straight up with the chimney flue as there is another commercial unit overhead. The oven will however be built against an exterior wall.
    Can I turn the flue back to exit through the wall or would I need some sort of electric extraction?
    Thank you in advance for any advice,
    Andrew
    Ireland
