Building Indoors? Electrical extraction??
  • andrewpizza
    • Apr 2010
    • 17
    Hi everyone,
    I am opening a small pizza take away shop and have decided to use the pompeii oven plans, scaled up to a 5 foot internal diameter.
    My problem is I cant take the chimney flue straight up as there is another commercial unit overhead.
    The oven will however be built against an exterior wall. Can I simply turn the flue back to exit through the wall or would I need some sort of electric extraction??
    Thank you,
    Andrew
    Ireland
