Hello,
I've only posted a few time but I've been following the forum for a while. We finished building our POmpeii oven about a month ago. We've had three pizza firings already. I think things are going well. But, yesterday, I noticed a crack and a loose brick on the outer arch of the oven. It's the one next to the keystone. When I push it, it does move slightly so I think it's definitely loose.
So what should I do? Should I pry it out and re-install that piece? I'll probably have to grind out the mortar on both sides so that I have enough space to re-install the same piece. Do I use the same mortar (FB mortar)? Or is there some other 'fix' that can be done?
Thanks for any input.
Byung
Byung
