Is 6" and 7" too small for the chimney?
  • mpjfitz
    • 36
    Hello
    I'm in UK. Typical over here, finding 'anything' to build the oven is a nightmare
    I can get 6" and 7" diameter pipe for the chimney quite easily and at a reasonable price. However, 8" is difficult to find.
    Has anyone used 6" or 7"? with good results?
    Any advice will be appreciated
    Mick
  • KraemerBAC
    • Jun 2009
    • 223
    Re: Is 6" and 7" too small for the chimney?
    What size oven are you making??
    Peter
    Member WFO-AMB=WW
    • mpjfitz
      • 36
      good question
      42" pompeii
      • FIREANDFLAMES
        • Mar 2008
        • 104
        I made a 36" oven and have a 8" pipe and it is about 5' high it works very well. I would suggest you get the 7" if you cant get the eight. But try to source the 8" pipe.
        • nissanneill
          • Apr 2007
          • 1886
          6 or 7" will almost work but I will guarantee that you will get abundant smoke out your front entry on light up. 8' is recommended and necessary and I will also add that a good funneled entry to your chimney will also help prevent smoke out the front and the chimney drawing well at all times.
          It is well worth the searching and maybe the added expense to get it right at this construction stage rather than trying to fix the problem later.
          Neill’s Pompeiii #1
          Neill’s kitchen underway
          • Neil2
            • Oct 2006
            • 1374
            " help prevent smoke out the front and the chimney drawing well at all times."
            Having smoke come out the front during firing is not a problem for me. Many of the pizza ovens you see in places like Croatia and Sicily have no chimney/vent.
