Kenny's 36'' Pompeii in Scotland
  • tallkenny
    • Aug 2009
    • 17
    Hi all,
    Finally got round to taking a few pics. Had a dry run with the floor and first couple of courses, cut half bricks using a hammer and chisel, will need a bit more finesse when it comes to smaller / more detailed cuts.
    Picasa Web Albums - 11336964747215976... - Pizza Oven Build
    When setting the floor level does it matter if I just use dry sand rather than fireclay/sand/water mix? Floor sitting on 4" of Vermicrete
    Made my indespensible tool today, next task is to discover how to post pics
    regards,
    Kenny
  • turkey
    • Apr 2010
    • 39
    Re: Kenny's 36'' Pompeii in Scotland
    for pics I would use a service like image shack, and when you upload let it resize them to 800,600 or something more forum friendly, then use .[img] tags arround the url it gives and bobs your uncle pictures in the thread
    • tallkenny
      • Aug 2009
      • 17
      1st attempt at adding a photo link....
      Picasa Web Albums - 11336964747215976... - Pizza build 1...
      • SCChris
        • Jun 2009
        • 1213
        I always add my photos by using the "Post reply" then "manage attachments" and select the photos by browse and upload.. This isn't working for you?
        Chris
        • tallkenny
          • Aug 2009
          • 17
          Another go!
          • tallkenny
            • Aug 2009
            • 17
            See if I can get them come out a bit bigger!
            First couple of courses in place
            • SCChris
              • Jun 2009
              • 1213
              Hurah!!
              Chris
              • tallkenny
                • Aug 2009
                • 17
                Inner arch pics, I used a wooden form and there is a triangle of brick hidden behind the mortar on the larger couple of joins.
                • tallkenny
                  • Aug 2009
                  • 17
                  No football today so made a little progress another course or two and starting to tie dome in with arch
                  • cannyfradock
                    • Nov 2009
                    • 96
                    Nice progress and good pics
                    All the best with the rest of your build
                    Terry
                    Honi soit qui mal y pense
                    My 2nd Pompeii build.....
                    http://www.fornobravo.com/forum/memb...eii-build.html
                    • tallkenny
                      • Aug 2009
                      • 17
                      Nice weather today, another couple of courses done, had to pick up my 4th tub of readymix mortar, will likely need a 5th tub after the next course, bit of a pain as it's not cheap at ?32 a tub.
