is 6 foot too long ...
  • mpjfitz
    • 36
    ... for the chimney pipe/flue?
    After much searching I have found an eight inch diameter stainless steel pipe for the chimney for my 42 inch pompeii. It really is pefect and at the right price = nothing
    It's 6 feet in length and I'd like to use the all of it. But before I do I was wondering if it's possible to have the chimney too long?
    Any advise will be appreciated
    TIA ... Mick
  • BackyardPermaculture
    • Mar 2010
    • 151
    Re: is 6 foot too long ...
    Hi Mick,
    My chimney is 6 feet long; it's a 6 inch interior pipe, made from 3 foot sections. With just 3 feet in place it didn't draw nearly as well as 6 feet. The longer the better, as I understand it - use all of it!
    Cheers,
    Mick
    My Clay Oven build:
    http://www.fornobravo.com/forum/f43/...dah-12821.html
    • oventhusiast
      • Mar 2005
      • 137
      I hope not! I just went up another two foot clay flue section on my oven to get the smoke away from our seating area for a total of six feet! I think we,ll be fine. Maybe the wood will burn a bit faster and hotter due to more draft? Besides, some indoor ovens have flues that go to the roof!
      View my pictures at, Picasaweb.google.com/xharleyguy
      • WoodchuckDad
        • Apr 2010
        • 209
        When you talk about wood stoves (the kind you heat with) the Chimney is the engine that drives the stove. longer chimney heats up, and draws creating a constant bath of air across the fire and removes the smoke. Your longer chimney will work quite well for you. I have a 12 foot pergola being built right over my oven and will have to go up 2 feet above that. Not sure how high it will go but I'd bet that the overall length is gonna be more than 6 feet.
        WCD
        My slow journey to pizza.
        http://www.fornobravo.com/forum/f21/...ing-12769.html
        • jmhepworth
          • Feb 2008
          • 293
          All depends on your enclosure. It won't be too long to work. It might be too short. In chimneys, taller draws better.
          Joe
          • nissanneill
            • Apr 2007
            • 1886
            mpjfitz
            My 40" Pompeii chimney is 8" diameter 12 foot long and works an absolute treat. It draws exceptionally well and the only time I have ever seen smoke coming out of the front arch is when I was using a leaf blower at full throttle to get some stubborn wood to burn. Only happened once and on the odd occasion, I only idle the blower to get the initial fire really going.
            Provided you have a good or generous transition to your 8" flue, you won't have any problems.
            Cheers.
            Neill’s Pompeiii #1
            Neill’s kitchen underway
            • oventhusiast
              • Mar 2005
              • 137
              I fired my oven with the new, longer 6 foot chimney (3 two foot clay flues) up on Saturday afternoon (6/26/10) and it works even better than the 4 foot chimney did!!! It draws great and I noticed that when the heat started to climb, it really started to turn the oven 'white' almost all at once! I looked up at the top of the chimney because I saw somewhat of a 'sooty' smoke, but when I looked back in the oven, was clean 'white' in seconds! I'm sure it's because of the added 'draw'! I'm very happy with it's ''new performance!
              Rick
