Here is an update on how heat retention changed in my oven when the entry materials changed. The first number is at the close of the oven after the last wood has burned significantly down. After Pizza. The second number in each set is 24 hours later, the third is 48 and the forth is at 72 hours.
The first set of numbers are my first high temp fire at the end of curing. What I’d like you to note is the quicker loss of heat related to the second set of numbers. These second set of numbers are a few firings removed from curing. I attribute the change here to the continued drying of the base.
850 400 230 140
850 500 385 245
850 350 200
850 500 400 250 - ? - ? -and 108F 7 days later.
Now compare the second set of numbers to the third set and you’ll note that the heat retention drops significantly in the third set. This change is attributed to a few things, but the major change relates to replacing the front entry floor brick with soapstone. This floor continues under the insulated door and up against the oven floor but does not continue into the oven.
Now compare the fourth set of numbers to the second and third set and you’ll note that the heat retention is now better than any of the preceding set. The soapstone that ran under the insulated door has been replaced with the original firebrick, essentually back to the same original, as built, configuration.
I think that the positive change in heat retention relative to the second set of numbers comes from the additional drying of the concrete base. When the forth and third set are compared the retention change is due to the much higher heat transfer rate of the soapstone, under the door, when compared to the firebrick. Soapstone has a 6X faster heat transfer rate when compared to brick.
My next set of numbers will be after replacing the firebrick under the door with a 1 inch break of rigid insulation board.
Chris
850 400 230 140
850 500 385 245
850 350 200
Chris
