I know it all depends on what you want to use the oven for with its residual heat and all.
But I'm at a stage where my oven build is almost complete and am currently curing the oven with a series of low to med temp burns using charcoal briquettes.
Even at this early stages of firing, I am amazed at which I can retain smoking temps for over 12 hours with just a grill basket full of charcoal briquettes and several full bricks covering the entry constricting air & exhaust flow in and out of the chamber.
Like most everyone else, aside from doing just pizzas I'd like to use the oven for other things, including smoking, where some airflow is required.
I'll eventually get into baking bread or anything which requires use of prolonged residual heat, but for the time being I think all I need is a simple metal plate door with perhaps an oven thermometer attached to its face. Air flow can be controlled by simply leaving a narrow gap between the door and the oven entry instead in installing adjustable air vents. Thoughts?
George
George
As I mentioned, I believe the FB door is steel plate, it will work, and by far, it is easy to fabricate.
