Mortar required to build a 42" dome
  • james
    Brick Oven Merchant
    • Mar 2005
    • 4648
    Does anyone have the calculation for how much mortar they using building a 42" dome? A builder just asked me.
    If you made your own mortar (either recipe), could you total up the weight?
    Thanks.
  • PizzaMan
    • Mar 2005
    • 49
    For my 42" dome I purchased:
    4 5-gallon buckets of sand
    2 60-lb bags of cement (not concrete mix)
    3 bags of clay
    After finishing the dome I have left over:
    1 5-gallon bucket of sand
    1/2 bag of cement
    2+ bags of clay
    I really does not take much to build this project. Just buy a little more than you might possibly need so you can pass on the leftovers to someone else!
    • maver
      • Aug 2006
      • 571
      I used the 3 part sand, 1 part fireclay, 1 part lime and 1 part portland recipe and used just under a bag each of the portland and lime (80lb each) and just over a bag of fireclay (60#), call it 80#. I didn't count the sand bags, but I guess you would figure 240# give or take. I used some of the sand and fireclay under the bricks of the hearth.
      • james
        Brick Oven Merchant
        • Mar 2005
        • 4648
        Thanks for that,
        I am estimating the following from the 3:1:1 recipe:
        150lbs of sand
        50lbs of Portland
        50lbs of Fire clay
        That's about 250lb of mortar. How does that sound?
        What would our other builders say to that?
