Napa WFO dome & hearth build questions
  • Dino_Pizza
    Re: Napa WFO dome & hearth build questions
    Eric, most everyone (including me) used a 12" height for the inner arch. Mine came to 12.125" in the center. At the outer edges, it depends: I went 3 brick high (on the arch walls) and a small mortar joint so by edges are 8" and peak up to the 12.125". It's got a nice curve. Many others went 4 brick high on the side walls so they went about 10.5" to the 12" center. Depends on if you want a gentle arch or "arch-ey" arch.
    If you want to get technical: 63% of a 19.5" center dome height is 12.28". If you make your dome center a full 20" tall, then you can have a 13" door height but (personally) I think shooting for an 'anything just under 20" dome height' is a worthy goal. Too tall and you waste your heat up there. True Naples style ovens have a low dome for pizza's , Tuscan style ovens have a higher dome.
    So, dimension 'A' at 20" is perfect. The B & C taper can be what's comfortable for you and what looks good. I think any taper (widening or flared entry) is nice. At 1st glance, it adds a bit of complexity (teensy) but I was able to do it successfully (after copying what Christo did ) and have seen so many others over the last year that also did it with ease & success.
    This pdf is my as-built of all those dimensions you asked about. Please ask again for any other dimension you need or we missed.
    -Dino
  • EricU
    ...My door height is going to be 13" which is about the 63% everyone recommends...
    I currently have another drawing for the front arch(s) which I have not posted yet as I wanted to get the plan dimensions straight first. I have mine set at 17" clear.
    I thought the FB instructions said 17" or 18" high, what is the correct opening height?
    I just read from one of the sticky posts "If you have a 42" oven, with a 20" dome, an 19"W x 12"H opening should work nicely. Good access, good thermal characteristics."
    So I think I will change my door opening height to 12" or 13" at the high point clear of the arch.
    What are other people doing?
  • dlebla
    I'm very interested in this post as I have just started to do the same drawings for a 42" WFO. The questions I still need to figure out are the dimensions in question as well as the dimension between the inner and outer openings. Not sure how much room I need there for the chimney. What are you using to draw your plans? I'm no engineer but I do have access to a few different CAD software which I'm going to try to do once I finish my rough sketches. How high is your dome? I'm thinking of going 21" which will make the indespensible tool very easy to use and create, I think. My door height is going to be 13" which is about the 63% everyone recommends. I have the same dimension on my plans for DIM A (20").
  • EricU
    started a topic Napa WFO dome & hearth build questions
    [IMG]
    I am getting ready to start my dome and have some questions regarding the hearth opening dimensions.
    I was planning on a 20" inner hearth dome opening (dimension "A") Is this a good dimension?
    Does anyone have any recomendations for the dimensions that I have shown on the attached plans?
    How much of a set back from the inner hearth dome opening (dim "A") should the outer hearth opening start (dim "B") be to give the door a place to rest.
    Should the hearth walls (dims "B" & "C") be different to give a taper? If so how much?
    Thanks for the help, Eric.
    My build thread
    Dome build pics
