I am about ready to add the insulation blankets around my my dome. My enclosure around the dome will be stone as shown below. The stone will NOT be a veneer mounted to cement board. It'll basically be stacked and mortared stone. The space between the stacked stone and ceramic blanket over the dome will be filled with loose popcorn size vermiculite. My concern is that moisture will get through to ceramic insulation and/or the dome. Tscarborough suggested a moisture barrier.
What can be used for the moisture barrier?
Will I need cement board betwen there?
Will I need some sort of vent to drive moisture out?
Thanks,
Bob
Thanks,
Bob
