i have been delinquent in posting my progress, but i am about 6 brick cuts from finishing the dome of my 36" oven. i hope to have my chimney arch finished by the end of the week and want to start to stucco next week. can anyone point me to a good instructive thread on "how to stucco". i live in Michigan, so its going to have to be freeze/thaw resistant and waterproof...
stucco questions
Re: stucco questions
This application is a little different than normal stucco specifications. I am thinking through the best way to solve the 2 major issues with traditional stucco applied to a monolithic hemisphere, but am not in agreement on the best way to do so yet.
As it stands, the normal method is to apply lathing over the insulation, then apply 2 or 3 coats of stucco, then apply a sealer of some sort.
The issues are cracking and water penetration, both of which are exacerbated by the shape and requirement for the stucco to be monolithic.
For basic stucco info, this is a pretty good site:
ApplicationComment
i just got done using the STO products. base coat was easy to apply with a trowel, finish/color coat was difficult. directions said to use a trowel! if i could do it again i would use a roller! stuff was like paint with sand in it. 10 minutes after i finished it started to pour, so i had to cover with tarp in a hurry. results were not great but i can live with it, attached is pics of 2 coats4 PhotosComment
The people at STO threw in a quart of primer that goes on before the final coat. I need a clear/dry day so that i can get the final coat on this thing before it snows. I think I'm going to have a couple of grout floats ready when i try it.. the Stolit is 1.5 medium grade, and looks like runny oatmeal..Comment
You do not want to use a grout float with an acrylic finish like STO. You should be using a steel trowel and hawk to apply the material quickly. Then use a plastic float in a circular or figure 8 motion to smooth, level, and texture the product. A grout float will lift the product off the surface.Comment
The thing about these products is that it takes years of practice to really get anywhere with it. I grew up in a stucco family, so I was born with Hawk and Trowel in hand, and even with 10 years of playing with the stuff I still make some big mistakes with the floating process. The best thing I can recommend is to do a quick practice and warm up on some durock before you go to the dome with it. A good half hour of practice/warm up will get the muscle memory going before you get to the real thing and that will help. Also smaller trowels and floats will make the process easier and faster, they are easier to control.Comment
thanks for the tips Nic. I did the Stolit 1.5 saturday, used a steel float and a drywall knife to apply it and then worked it with a hard plastic float. It turned out great, and really didn't take very much time to finish... more worry than work... did pizzas for the third time Saturday nite, only one burnt offering, and no burned bottoms.. i do need to work on my dough recipe to get more of a thin cracker crust...Comment
look at my build I used 2 coats of STO with sand in it with a steel trowel and i made a texure look...Comment
I wasn't going to post any pics till i was done, but... i went to the Newbie forum, uploading pictures, and have tried a half a dozen times to upload a couple of shots i took last night. can't get it to work. i'll do a little more reasearch, try again, or just get my IT guy in here to help me figure this out....Comment
