Pompeii Oven Stand Height
  • lhuhn
    • Jul 2010
    • 22
    I am getting ready to set the blocks for the oven stand tomorrow and I have questions about the recommended height of the stand for a Pompeii oven. The plans call for four courses of 8" block for a total of 32" to the bottom of the hearth. With a 3 1/2" hearth + 2" FB Board + 2 1/2" Firebrick that puts the floor of the oven at 40". It seems to me that adding another course of block to the stand would make things a lot more user friendly (less bending). I know this is an individual choice but I am wondering if there is a good reason for making the stand shorter? Any thoughts?
  • Tscarborough
    • Oct 2009
    • 3341
    Re: Pompeii Oven Stand Height
    I bent my elbows to almost 90 degrees holding the peel and measured to the ground, that is the height I made my hearth, 41-1/2". That said, I do have to lean over to look into the oven standing right in front of it, so I generally stand back about 5 feet and don't have to bend to see.
    Bending over is easier than working a tool above that 80-90 bend of your arms.
    • fxpose
      • Jul 2009
      • 942
      Perhaps because it was originally designed by a shorter person like myself? I am just over 5' 7". Five courses will bring the hearth too high for me.
      George
      My 34" WFO build
      • GianniFocaccia
        • Jun 2009
        • 1645
        If you have shoulders like mine (destroyed from years of overuse caused by youth sports) you will appreciate not having to stress them by having to lift a peel. My recommendation: take a broomstick and slide it horizontally at whatever level is comfortable to your shoulders and back as long as you can see the end of it (ala TScarborough).
          I make mine 4 courses of 8" high blocks, then plus slab and floor gives me a working height of 3 ft. I have heard elsewhere that the ideal is 1 m which is 3ft 3" you will adapt to whatever you build but the 3 ft height allows seated guests to be at eye level to the fire which is nice.
          • mklingles
            • May 2010
            • 93
            I went with 5 rows of block. However, I'm 6'5". Also I just finished it and haven't had must time cooking with it. I think it will work well.
            http://www.fornobravo.com/forum/memb...d-im-ready.jpg
            My oven build: http://www.fornobravo.com/forum/f8/m...and-13300.html
              Yehesss !!
              • lhuhn
                • Jul 2010
                • 22
                Thanks everyone. I decided to go with 5 courses.
                • kebwi
                  • Aug 2009
                  • 1090
                  My stand is four courses, so about 32". 3-4" hearth, 3" insulation, 2.5" firebrick. That's an oven floor of about 40". At my height of 5'11" it feels perfect. I'm sure some variation would be workable, but a full course of blocks would be too high for me...I presume, I have no experience with a higher oven of course.
                  How tall are you?
                  • WoodchuckDad
                    • Apr 2010
                    • 209
                    The best advice I received was to make sure it is tall enough. you can make it a small step in front of it to make it shorter, but you surely can't make it taller.
                    WCD
                    My slow journey to pizza.
                    http://www.fornobravo.com/forum/f21/...ing-12769.html
