my homemade door
This shows my homemade door, made from a sheet of stainless steel. I have a Insblock 19 board left over that I will cut to fit into the inside of the door, then a buddy will weld stainless strips between the two halves of the door to encapsulate the insulation inside.
So that's why I decided to use the tar paper (I think) as opposed to the Tyvek. Perhaps I'm worrying way too much about moisture but living in CT I know that trapped moisture can cause problems...
