Double ridge beam is the BEST house frame improvement
(M) IMHO the double ridge beam is the single most important contribution to the framing of the oven enclosure I have seen. Kudos to you and your dad. The solution is a perfect example of "thinking outside the box". I wish I had thought of it before I curved my flue to avoid the ridge beam.
(M) I had posted a caveat a day or two ago during the time that there was some FornoBravo Forum complications and I guess you hadn't had a chance to read it prior to putting your roof up. It was the suggestion to clad your walls FIRST and only then put on the roof. That order would make attaching the top of the cladding under the eaves much easier. You would then put up your roof exactly as you did.
(M) I decided against flue tiles all the way up as their weight was over 125 pounds. But your framing is so much stronger than mine that I think you'll be fine.
(M) I had considered notching my top flue tile to accomodate the ridge beam but several forum builders discouraged me from that because of the hot smoke weakening the ridge beam. I have photographs of that as well as my solution of using single wall flue pipe and elbows to "S" around the ridge beam and place the chimney to one side of the ridge beam. The metal flue pipe was much lighter than clay tile. I wrapped it in chicken wire and then insulated it with Perlcrete.
(M) If you want to see more of my less than elegant solution go to:
Ciao,
Marcel
Ciao,
Marcel
