Hi all,
Long time since my last post. A few years ago, with the help of this forum and its plans, I finished up my outdoor 120 cm oven. Since me and my wife like cooking and entertaining, this oven has during the last couple of years seen very heave use with maybe 400 pizzas, bread, meat and chicken roasts. For me firing up the oven is quite a relaxing experience and cooking with it is much more rewarding then a regular electric oven even without counting the much superior flavour that you get.
But my oven is outside and soon the winter is coming. Even though I sometimes fire up the oven in the winter, it is not used for the majority of the time. Which leads me to start thinking of an indoor pompeii oven. In the next year or so I may start a new home construction and want to incorporate an indoor oven as a central piece of a large kitchen.
If the oven was indoor I could see my-self firing up the oven at least twice per week. If the oven was indoor and used that much for cooking then I was wondering if it can have dual use to also heat the house somehow in the winter time. I have underflow heating system and was thinking of incorporating on the outside of the dome (before the insulation and exterior cover) copper tubes that will circulate water that would be heated and either stored in a water tank or circulated in the underfloor heating system.
The only problem I see is that the water tubes may need to be empty when you want to use the oven for high heat cooking since other wise they may take away to much heat from the dome. Maybe this can be solved by having a mechanism to empty the tubes when its needed.
What do people think about this idea? Any other problems which I have not thought about? Could be interesting to come up with a new forno bravo design all together
Any thoughts are welcomed.
Kosta
Kosta
