I am starting to think ahead to the vent design and construction and have a few questions and I can't find the answers in other threads.
First, is there a vent opening size ratio? In other words, if I am building a 42" high dome oven (and I am) and use the opening size of 20"x12.5" as recommended, do I need a vent opening size of ? square inches?
Second, if I opt for the concrete vent construction do you need a special concrete mix or just basic concrete mix?
Thanks in advance
Thanks in advance
