Re: Compact 36" in Seattle
Portable hearth eh?
The challenge is the weight of moving. Seeing that you are in a seismic area, code will require that the unit is tied together.
If it were me, I would not fill the blocks flush but leave about 1 inch of hole underneath and then put in a bond breaker so your hearth will be lego like. Either way, you will need a forklift for moving the hearth and or Heath/oven combo - easily looking at 1500 pounds.
If your neighbors complain, give them a few pizzas. If they continue to complain, drop some phenolphthalein (a pH indicator) in the crust - gives ya the runs and does not have much of a taste. That is pure evil genius and works - did it to a few of my "classmates" in college who screwed me during exams on several occasions (I ended up on the low end due to my integrity and not cheating.) - should have seen them running out the door at the end of a 3 hour final
. Yes, I got the last laugh and my advisor/professor laughed about it and a brilliant technical way to get even. The stern lecture I received from the Dean, grinning the whole time, put it in perspective.
Portable hearth eh?
