Okay I laid my block and the stand is finished, looks real good the only thing is the angel iron is going to be a little problem if I decide not to brick the front I will have to put some wire mesh and then stucco over it.
I started at 9am was finished by 330. I will frame and pour the hearth this week end, no straps 2x8's framed around the edge and supported with 2x4 and a couple of 1x,s on an angle bracing the top of the form will be pleanty also not to wet of a mix. will let you know how it goes.
