Stucco Question - cold line?
  • Paul in Rockwall TX
    • Nov 2010
    • 52
    I'm planning to stucco over the concrete block and concrete board construction. I already applied the mesh. question is, can I do this in batches, or does stucco have to be applied in one process? I know the directions say not to allow cold lines (where one batch is cured at the edges). but I don't think I can work that fast without help, which I generally avoid. anyone ever done this?
    I'm using a premix product, TXI Spec Mix Scratch & Brown.
    PhotoPlog - Enclosure
  • Tscarborough
    • Oct 2009
    • 3341
    Re: Stucco Question - cold line?
    You should lath it in panels. Otherwise you should stucco to natural breaks and edges.
