OK, so I have read loads on the forum, but nothing really answers the basics questions I have.
Firstly I an intending to build a mini pompeii oven (30") with an internal diameter of 25.5 in, I have already constructed the concrete hearth base, so here comes the questions.
1: What thichness should the concrete hearth base be? I have currently poured a 2.5in base with 10mm reenforcing bars, and am thinking this should be considerably thicker?
2: Should I place an additional insulation topping on the hearth and then place a firebrick floor on top of that, or would 65mm thick firebricks directly on teh concrete hearth be sufficient ?
3: Is a fire brick floor what I should be cooking on, or should this again be covered with something?
4: As my oven will be pretty small I am unsure of the oven dome height, I looked at some figures and tried to work out a proportional ratio
I rekon for my 25.5in internal diameter a dome height of 13" from cooking floor to ceiling does this seem to shallow for the dome height.
look forward to comments
