Hey everyone,
So, as the title suggests, I'm having a little bit of a crisis on what I'd like to do, but is it feasible -- sort of thing...
Anyway, here's my dilemma... I've put a nice 4 1/2 inch thick slab to form my hearth and acquired some of this "Insblock 19" fibreboard stuff for my under-cooking-floor insulation... Now I've been reading multiples of that it's good stuff, and how it can withstand the weight of the oven being built on it (etc etc)... On the same note, I've been reading how if the stuff gets wet, being fibre board, it turns into a sort-of mush and becomes rigid again when it dries out...
This, for me, is concerning. Because I'm intending to (like most people) do a 'one time build', I'm having difficulties coming to terms that the insulation may become weak/move/break down in the fullness of time...
One idea I came up with, and this is where I need your help and experience(s), is to build a 3" 'frame' around the insblock layer (noting that the insblock is only 2" thick) and pour a layer of Vermiculite-portland mix to encase the insblock... thereby giving it a 'hardened, airtight, layer/shell' thing...
My worry concern was that the Vermiculite on top of the insblock would only be an inch thick and I am worried that this might also break down when the bricks are hot owing that it is a lot thinner than the recommended 3" layer that is usual where insblock/fibre board isn't used...
Does this kind of make sense to anyone...?
All experiences welcome. Thanks all.
