Re: insulate before curing
LOL... I have a family full of engineers. It's not to be harsh it just takes me twice as long because I have to explain everything...in small words...and draw lots of pictures. So it takes twice as long.
SO my thinking is
If you insulate then you'll want to protect your insulation from outside moisture, bugs, birds and little kids that want to play. so you insulate then stucco. A vapor barrier works both ways no moisture in and none out. So if you try and cure the oven after insulation and stucco you will trap moisture in the insulation layer. That just prolongs the process
So why not cure the oven first?
Originally posted by lwood
View Post
SO my thinking is
