Insulating slab question
  • cholme
    • Aug 2007
    • 62
    I finished my structural layer and poured my insulating layer using about 4 parts vermiculite and perlite to 1 part portland cement... no other aggregates. It is only a day since the pour, but it seems like I could easily a knife through it. In other words it more resembles hard sand, than cement. Is that normal? What should this layer feel like?
    Thanks in advance.
  • Lburou
    • Dec 2010
    • 1165
    Re: Insulating slab question
    Thanks in advance.
    Your description and concern are common threads here.
    The vermicrete will support a lot of weight, despite its crumbliness. Give it a couple more days and you should be ready to start
    Lee B.
    DFW area, Texas, USA
      • 9216
      You can increase the strength of the insulating slab by adding sand to the mix, but you also reduce the insulating value. The 5:1 mix has been proved to have adequate strength, so it's best to stick to the plan.
      • RTflorida
        • Jan 2007
        • 1446
        LeeB pretty much covers it. It will have very good compression strength, but always (even when fully cured) remain crumbly. Give it a full week to cure if you still have an uneasy feeling, it will be hard then (but still crumbly).
        Don't let the rain get to it, you wil have a runny oatmeal mess if you do...its far from weatherproof and absorbs water better than a sponge.
        RT
        • Neil2
          • Oct 2006
          • 1374
          As for any portland based material, after the initial set (10-12 hrs), keep it wet for at least 7 days. If you inadvertently allowed it to dry out, you may have to rip it out and re-pour.
          • Cheesehead
            • Aug 2010
            • 42
            Mine was "crumbly" for days. But I kept it covered, and voila! a week later, it had the consistency of styrofoam. Yes, I could dig at it if I wanted, but it was pretty solid.
            Just layered some on top of my dome. Perfect curing conditions - the oven is under a canopy, but it's going to be raining for the next few days (100% humidity).
