I recently calculated the prices of the materials I need for my Pompeii oven and am coming well over ?800 (ca. $1,140). Here in Ireland everything seems to be more expensive.
Locally sourced firebricks would cost me ?3 ($4.30) each, vermiculite is at ?23 ($33) per 100 litre bag (which is only about 40 cubic inch). These are really the two bad boys that are making the whole thing expensive.
Anyways to get to the point I really need to save materials and to save on vermiculite I was thinking about walling in the dome and filling it with something cheap, maybe sand or rockwool as insulation. I might be able to add 5cm (2 inch) of vermiculite concrete on the outside of the dome which would correlate to two bags at the very most.
Would this work?
P.s. Also if anyone has the conductivity or resistivity of the aforementioned materials or other alternatives It would be very helpful for me to calculate the u-values, thanks
Would this work?
