Here is my latest oven, oven number 3 in the curing phase.
  • brickie in oz
    • 3445
    Here is my latest oven a Pompeii dome, oven number 3 in the curing phase, the fires are hard to light as expected due to the moisture in the oven.
    YouTube - ‪New Oven.MOV‬‏
  • chidding
    • Jan 2011
    • 176
    Re: Here is my latest oven, oven number 3 in the curing phase.
    Haha thats awesome, reason for the project?
    • brickie in oz
      • 3445
      Because I could..
      • chidding
        • Jan 2011
        • 176
        You best be making a full set of mini tools. And a full outdoor kitchen to match.
        haha this is legendary,
        • brickie in oz
          • 3445
          Originally posted by Karangi Dude
          Al,
          You will be able to take that to work to toast your cheese bread sandwiches and pides.
          Al that is a pissa an Aussie first, you sure are a true Aussie bloke with a great sence of humor.
          I want one could you please post some of the dimentions.
          Cheers Doug
          Its 1/4 scale modeled on a 1200mm oven, I used all of 5 full fire bricks.
          Size is 300mm diameter.
          I even made an indispensable tool.
          Its all refractory, Im going to put some ceramic blanket on it and render it.
          I even kept with the golden rule of 63%
          • brickie in oz
            • 3445
            The base board is 40mm calcium silicate, there is a fire brick hearth in there too, all 5mm of it.
            • brickie in oz
              • 3445
              For the glue I used refractory glue, same glue I used in oven number 2 (the real build)
              Some more pics of the mini build.
              • brickie in oz
                • 3445
                And the Red Wine?
                Ah Glasshopper, you are very observant.
                It gives the inner creative being a way out to the outside world.
                  That is so cool. Can you get a roaring fire in an oven so small though? The smaller you go you have to make the flue bigger, ie it doesn't work if you just scale down the dimensions. You need to make the flue bigger relative to the volume as you scale down the dimensions. I discovered this when making a small kiln for firing ceramic jewelery.
                  • brickie in oz
                    • 3445
                    Originally posted by david s
                    Can you get a roaring fire in an oven so small though? .
                    I doubt it, I should imagine the smaller you go the thicker the air will become relative to size of oven. If I could just scale down the air molicules it may burn?
                    I was hard pushed to keep the fire lighter going, maybe its just a damp oven?
                    • brickie in oz
                      • 3445
                      Actually the flue worked just fine I was surprised.
                        Would it be too difficult to increase both the mouth and the flue area? Angle grinders are great tools. The other thing is that it is really easy to overload the chamber with fuel in a small oven. If too much oven volume is filled with wood then there is not enough volume for combustion.
                        • azpizzanut
                          • Aug 2010
                          • 397
                          Brickie,
                          Finish the render in blue, then place Smurf characters around it for scale effect. A scale pizza peel and pizza would be nice too.
                          Cheers,
                          Bob
