This is a build log or is it blog of my pompeii oven. I am using the standard plans as my basis with some changes I have seen on the forum and a few twists of my own.
The internal diameter is 900mm which is 35.4 inches, so nearly a 36 inch oven !
The base is made of blocks with a ground smooth finish plus two brick arches. So there is plenty of room for wood underneath. The blocks were a small lot from a factory outlet and really well priced.
Boxing for floor is made of blocks cut down the centre so the floor is contained withing the blocks. This worked well but cutting was really dusty and you could not do it without a diamond wheel.
I have set up the floor within the block work so the oven floor will ultimately be level with the coping bricks that will finish on top of the blocks.
On top of the concrete floor I have about almost a 2 inch layer of vermiculite/cement 5:1
I know this is thin but I am using 2 inch Calcium Silicate board which by the plans is sufficient insulation by itself. The only reason I used vermiculite under the Calsil board is to get my floor level where I wanted it.
I have read about making the vermiculite/cement and tried both methods dry mix with cement then add water and mix cement and water then mix with vermiculite. I prefer the dry mix with cement first but either way I found it is difficult to work with.
Pictures are attached .... more to follow soon.
Brett
Brett
