Refractory Cast Dome Top?
  • md_massimino
    • Sep 2010
    • 48
    I just finished closing in the top of my oven (finally!!) and was wondering about the feasibility of using a custom cast refractory dome past courses 11 or 12.
    I built a platform inside the oven and put down a sand form to support the bricks for the very top of the oven:
    As I was looking at the completed pics today, I started to wonder...what if using this method you simply made a batch of refractory mortar and poured that into the void and shaped it to the final curve with a trowel? It would need some reinforcement with wire or maybe rebar but it seems like it would be a much easier and better solution.
    Any thoughts? This is more theoretical at this point since I've already finished my oven with the classic method.
  • Evets
    • Nov 2009
    • 55
    Re: Refractory Cast Dome Top?
    I don't think refractory "mortar" would be a good idea, but a refractory concrete such as Harbison Walker KS-4 would probably work, along with re-inforcement. I think they use stainless steel pins instead of wire for refractory concrete.
    http://cgi.ebay.com/Refractory-Reinf...#ht_500wt_1156
    Build Thread, http://www.fornobravo.com/forum/f8/e...-pa-13750.html
    • md_massimino
      • Sep 2010
      • 48
      Oops, I meant to say refractory concrete. I still mix those two up even though I know the difference.
