Continued Design Ideas
Re: Continued Design Ideas
Here are the latest progress images.
Laying brick has gotten easier and faster but I still struggle at times; had to build the upper arch three times before I got it right.
I surrounded the vent and first flue piece with 6:1 perlcrete to give support to the chimney. I'm also thinking of building some kind of support out of metal studs to pick up the load but haven't decided quite how to do it. I'd love to hear your ideas.
I'm planning to build scissor trusses for the roof and anchor them to the brick walls with allthread and grout since I'm six courses above the last tie. I also have some left over rebar that I could grout in. I tied the arch and front wall to the vent structure with wire mesh which is also encased in the perlcrete. Not sure if this is overkill or if I still need to do more. I don't want these walls falling off if we ever have an earthquake since this oven was intended to be part of my emergency preperation.
And one last question. I have a piece of left over granite countertop that I'd like to use in the entry instead of the firebrick but I'm worried that the heat will damage it. Anyone have any experience with this?
CraigLast edited by clofgreen; 05-28-2012, 08:24 PM.Comment
Clofgreen,
Looking at your brick work closer and noticed in the background some espaliers?? Umm, do we wfos think similar? I am training a couple pears espalier trees. Will hook up with u on the CaSi when i get back.
RussellComment
Craig, I and others have used granite in the entry, away from the direct fire, and it seems to work out. If you allow for replacement if needed, you have a gracefull "Plan B". If you go this route, take a bit of extra effort and slightly slope the granite so that any water that might ever get into the entry drains out of the front.
Oh! Also setup a break in the oven floor to minimize heat transfer from the oven interior to the entry floor and under the oven door, even a 1/4" gap to be filled with ash will make a difference and slow the heat flow.
ChrisLast edited by SCChris; 06-04-2012, 08:08 AM.Comment
I had a day off last week so worked on the oven. Here are a few pics.
I built a frame out of metal studs that I embedded in the perlite. It gave a level and firm surface to lay the chimney bricks. I built a beam out of two metals studs with two back to back tracks on top which I attached to the chimney base on one end and an opening in the bricks on the other.
I'm trying to decide if I should grout the beam into the wall to anchor the wall or if the expanding metal studs would weaken the wall.
I attached studs, filled the cavity with perlite and attached a layer of OSB. I'm still not sure what I'm using as a finish roof material.
Yes, I have a pear espalier. I've tried to turn my back yard into a mostly edible landscape. High maintenance but totally worth it.Clofgreen,
CraigLast edited by clofgreen; 06-11-2012, 06:29 PM.Comment
It is necessary in most building codes. In the pic I see a lot of wood and potential leaf fuel depending on the season and the weather conditions. You can make one out of construction cloth and just lay it over your flue exit. You will still need to build a rain cap though. The cap made from the same brick your build is made would look the best imo. But there are endless ideas and products out there if you do the search.Joe Watson " A year from now, you will wish that you had started today" My Build Album / My BuildComment
I think I'm finished (famous last words). Here's a couple of pics.
I don't think it varied too much from original design.
I'd like to thank the many wonderful people on this forum who gave great advice so that a total novice could pull something like this off. I hope I can give back even a portion of what I received here.
CraigComment
Craig,
Nice job. I thought I was good at finding and salvaging materials but after reading your thread, you are the king. Fine looking oven, you have set a high bar to follow.
RussellComment
that is pretty funny. I am planning to plant a couple of trees to espalier along the retaining wall behind my oven.
next question... anyone else roast their own coffee beans?Comment
