Re: Continued Design Ideas
Craig,
No problems with the bricks. They sure were very dirty when I got them too. I had to buy a few 1/2 firebricks from Bhuener(sp?) block downtown and our bricks are in a whole different league. They seem to be much harder. Just don't drop them, they chip easily.
Derk
Chris,
The tarp wrapped around the shelter and heat lamp has done well. On cold frosty mornings the temp stays right at 50 and during the day when the outside temp gets up to into the forties, the temp goes up to 60 - 65. The perlcrete has cured very well, hard and solid with only a few loose granuals on the surface. This is a 6 inch perlcrete slab so I'm hoping it will insulate properly and not make me regret not splurging on insul board. But at 10:1 under the oven floor it shouldn't (crossing fingers).
Derk
I've been watching for posts from you praying I won't read the words, "firebrick is cracking." I read a post where someone had bought firebricks that had been left outside and the freeze thaw had weakened them. Don't know how many freeze thaw cycles our bricks have gone through but am guessing given the amount of coal dust on the piles its been quite a few. I've also read that these super duper high temp bricks are intended for constant high temp firing and that they are more suseptable to cracking when heated and cooled many times. Again, crossing fingers that they'll hold up. Still hoping to get up to see your build but an already busy life has been made more so by trying to get this oven built.
CraigLeave a comment:
Craig,
It's coming along. For my slab I poured it 8" thick with a framed in depression 4 inches deep directly under the oven, leaving a full thickness of concrete to support the oven arches, the opening arches and the back wall of the oven. The depression was filled in with percrete, leveled with a little sand and our super duper "Geneva Steel" leftover firebrick floor on top of that. It seems to work well. Our floor is made up of a comnbination of 6X4.5X18 inch 3000degree firebrick.
DerkLeave a comment:
Looking good Craig.. Let us know how the curing comes along using the tarp and lamp.
Since you're up there in altitude and winter storms are starting to push through, I'll keep my fingers crossed for a bit of warmer weather without to much wind to steel the heat of your build.
ChrisLast edited by SCChris; 11-12-2011, 05:28 AM.Leave a comment:
Today was to be the last day before another storm moves in so I took half a day off work and poured my perlcrete hearth. It was fairly easy thanks to the great instructions on this forum. I did things a bit different though so I thought I'd document them. As I thought about the insulation slab it occurred to me that the place that needs the most insulation is right under the oven floor. Conversely, at the edges where the weight of the vault, vent and chimney comes down on the perlcrete it needs to be stronger but doesn't need so much insulation. So first I mixed a batch of 5:1 perlcrete and lined the edges, packing it down fairly solid by hand. I figured this is where it needed to be strongest to hold everything in. Here's a picture of the first layer. I added several more layers of 5:1.
Next I added several batches of 6:1 and hand packed just until firm. Finally, I added 10:1 under the oven floor, hand tamping very lightly. After I screeded the slab I topped it with a thin 5:1 final coat and tamped it lightly with a moistened trowel to flatten and consolidate the surface.
Here's how I mixed the 6:1 perlcrete. Using a number 10 tin can I measured four cans of portland cement into a five gallon bucket making it about 2/3 full. Next I measured 24 cans of perlite into a wheelbarrow, added four cans of water and mixed. Next I added water to the cement until the water was three inches from the top of the bucket. I mixed it using a drill and paint mixer attachment. This made just over half a bucket of cement slurry that had the consistency of thick syrup. I poured this into the wheelbarrow and gently mixed with a shovel until all the perlite was coated. This made a fairly dry mix but was just moist enough to hold together. I filtered this through a screen made out of hardware cloth (the kind used to screen rocks out of garden soil). Sifting it this way allowed me to filter out and break up any cement clods giving it a nice uniform mix.
To keep snow off, I built a makeshift shelter out of an old fence I tore down.
To keep the perlcrete warm while it cures, I clamped a heat lamp inside the shelter and covered it with a tarp. I plan to let it cure a week.
Was hoping to pour tomorrow but the latest report shows snow starting later today with 1 - 3 inches expected in my back yard. No time to set up a tarp and warm the slab. Looks like I'll have to wait. But thanks for your reply.
Hey Craig, Think about getting the slab warm before you pour. It wouldn't take much to get a tarp plus some blankets over things and then put a bare bulb in the wood storage area/s. The structure should heat a bit before your pour. Are you pouring tomorrow?
ChrisLeave a comment:
The mass of the concrete will temper things a bit, as long as the temps aren't sustained and sub-freezing wind aren't an issue.. You might think about throwing a few old blankets or comforters over the pour and heat from below.. Anyway, keep your fingers crossed for a few days of appropriate temps.
Actually, I'm not in Snowbird, I'm 12 minutes and 3500 vertical feet away (that road really climbs). But yes, we are getting below freezing quite often. Was 23 several nights ago.
I thought I might build a simple wood frame to support the tarp and hang the heat lamp from it. Just wasn't sure if a tarp was sufficient to keep the heat in or not.Leave a comment:
In Snowbird you must be getting some below freezing nights.. I'd expect that a lamp might be enough. Can you tent the whole structure?
I've built the forms for a 6 inch perlcrete hearth pour and am planning to use an 8:1 mix as Tom mentioned. But it is getting cold here in Utah, highs in the 40s, lows 28 to 30. I read that the temperature shouldn't go below 50 for the first five days so that the cement will hydrate properly. Would a heat lamp under a plastic tarp be sufficient or do I need to do something different?
Compromise to make it easy and use 8-1 under all. Also no need for blankets if you use perlite over the top.Leave a comment:
I pulled the forms and the hearth slab looks nice (left my camera at work. I'll post pics later).
EDIT: Its later, here's the pic.
Now it's time to think about insulation. I've read many posts about the value of insulation but am not sure I want to spend the $$ for all that Fiber Board. So here's my question:
Can I use a 4" 5:1 perlcrete slab where the heavy loads are and go with, say, a 10:1 mix where the loads are light, like under the floor? It seems to me that putting the 10:1 under the floor where it is hottest and not very heavy would be a good idea.
Similar question: If I put 10" or so of perlite over the dome can I get by without the fiber blanket?
Thanks for your help.
CraigLast edited by clofgreen; 10-26-2011, 04:41 PM.Leave a comment:
Great progress, and looking really good. And just an extra cup of water won't hurt the concrete strength enough to cause problems. I like the hardiebacker beneath the upper slab as a leave-in base... if I were building over again, I would go this route.Leave a comment:
