Re: Simon's 36" LA brick oven
Simon
I would lay out the rebar in a grid pattern. Calculate your rebar volume to total about 1.0 % percent of your slab volume and space it both ways evenly. Put a double bar in wher it spans the entryway.
The "radial" system that you are proposing is somewhat problematic in that you will end up with a mass of rebar crossing in one location and will have difficulty in getting adequate concrete cover on the rebar. Conversely, if some of the rebar is ended before the "centre" then you will have "dead ends" which will contribute much less strength to the reinforced slab.
Bending the rebar down into the concrete blocks, as you have done, is the best practice. Most people put verticals in the wall and bend them down 18 inches or so horizontally to provide an overlap tie to the grid rebar. This is done only to make the rebar placement more convenient. Having the rebar continuous in one piece is actually slightly better but provided you have adequate overlap (12 inches) then either technique if fine.
Simon
