How small
  • Hank10746
    • Aug 2011
    • 43
    #16
    Re: How small
    Chris
    Thank you for the help on the heat although I hope I build it right and don't have to use a way to keep the wood burning
      Re: How small
      Originally posted by Hank10746
      David
      Thanks, one more question what is the outside Diameter and height of your oven and door size? I think after I know your finished dimensions I will build a 24" oven. I will have 3 a small one then a 42" or a little bigger then for fun a barrel oven with the opening on the side. Then I can answer all the questions I have about each for myself. Use the the small one for my wife and I the barrel for bread and the big one and just sit and look at the big one. Have to have a hobby
      My oven outside diameter is 900mm (height 450 mm)
      Door (inner) 160 x 250 mm
